- Feb 8, 2014
- 11,176
That Square D thingy is the motor starter for the motor. A motor starter consists of 2 parts: 1) the contactor, and 2) the overload relay. Because the machine was apparently running on 460V, the heaters on the overload relay will be wrong, and will need to be replaced with the correct ones for operating on 230V. The heaters are those fuse looking things below the contactor. Your electrician should be able to help you with that.
That transformer has seen better days, time to remove it and sell it for the scrap copper. Replace it with a 250VA standard control transformer.
This will give you enough transformer capacity to provide the 120V control voltage and enough reserve to power a 100W lamp. Although I would install a LED lamp or maybe even a couple of them.
It looks like you need to replace all of the wiring, it looks a bit mouse chewed.
