I have a lot of balls in the air right now.
But I did have the opportunity to do more with my anodizing setup today.
In my previous post, I mentioned that I was getting some submersible pumps to circulate the fluids in the tanks, in favor of using the air agitation I had been using. They sat on the shelf a few weeks, but I finally had an idea that solved a few issues.
One of the issues, I haven't been happy with my heater element setup. Mostly, I haven't really
had a setup.
Since I am now going to use a pump with a manifold, I figured I could mount the heater element in a larger vertical pipe in the manifold. I could then pump the fluid into the top of the pipe and down around the heater and into the branches of the manifold.
You can see the pump is attached to the top of the standpipe. The outlet is inserted into a hole in the side of the pipe. The inlet is a short length of vinyl tube beneath the pump. I made the standpipe from PVC fittings.
I turned the fittings in the lathe and glued them together. One of the fittings has a female pipe thread that matches that of the heater element, one is a cap for the electrical connection. You can also see the pump in the foreground.
This is the pump and manifold in one of the tanks filled with water for testing.
I pointed the exit holes in the manifold in different directions in the hopes of creating a relatively random circulation. As it turns out, the pump isn't strong enough to squirt much of a 'jet' out the holes in the manifold, so it didn't matter where they were pointed.
It took a few minutes for me to figure out how to prime the pump (since it isn't submerged). The heater and pump worked well! There isn't much of a fluid stream exiting from the holes, but there is clearly some circulation. I believe it is sufficient for use in the degrease tank and also in the dye tanks.
I don't believe the circulation creates sufficient agitation for the anodizing tank, so I'll be looking into a different pump for that. I am quite pleased with this for use with the dye and degrease tanks!
