- Feb 28, 2019
- 530
So you would have to make a second plate with the same hole layout for the dividing head?
Any errors in dividing plate hole placement that is introduced by calculating and moving in X&Y on a mill will be reduced by the ratio of the worm/gear when in use. Obviously, we are talking about an angular error on the dividing plate - any radial errors won't affect the results of using it, other than making it hard to use the pin locator.
The point is, make any plates you don't have, make them by layout and drill/mill X&Y. You will then have an acceptable set of plates which presumably would allow you to make another set on your dividing head. (without doing a lot of math and plate hole counting, I can't tell you which plates can be used to make more plates, but that's the concept).
The second set that you make on your dividing head using any of the "sloppy" plates made on the mill will be 40 times more accurate (based on your worm ratio). If the sloppy plate hole is off by 1/2 deg, the hole it makes will be off by 1/80 of a deg. It's really that simple.
You can do this as many times as you like, however, once is probably enough for most work, twice is definitely enough - error is reduced to 1/6400.
Regarding the layout of the holes. There are a lot of them, and keeping track manually (cranking and watching dials or a DRO) will be challenging. I would lay it out using any reasonably good drawing program - or maybe CAD depending on what you have. You can then just print it out and stick it on the plate to be drilled (spray adhesive, stick glue etc. anything that will come off with solvent).
Most printers are very accurate in the relative repeatable placement of ink. What you need to account for is differences in X&Y scale. Print out a large square or just four points and verify what the printing "scale" is and also that X & Y are the same.
For instance, if you layout dots 6" apart, you will find that when printed they are not exactly 6" and X & Y may be off by different amounts. Calculate the correction factor in X & Y, apply it as scale in your drawing program and print & check again. This can all be done easily in Inkscape.
- Dave
