Not sure. Have not started doing a plate yet. but like others it would be great to have as many amounts of set ups on one plate as well so its not wasted.can you have more accuracy with the holed at a larger diameter?
That's a very good approach. You can then use the manually laid out dividing plate (CAD + MILL) to make a second using your dividing head, any errors will be reduced by the worm ratio of your dividing head, typically 40:1. You can do this as many times as you like but twice is sufficient.Well my plan would be to take a pce of round stock and bore the center hole. Then go to the mill and indicate center of the hole. Since i don't have a rotary table i would use a cad program and plot each point as a X and Y coordinate.
So you would have to make a second plate with the same hole layout for the dividing head?That's a very good approach. You can then use the manually laid out dividing plate (CAD + MILL) to make a second using your dividing head, any errors will be reduced by the worm ratio of your dividing head, typically 40:1. You can do this as many times as you like but twice is sufficient.
