I must admit to being a little confused by the thread, and the answers. Is this a mill, or a lathe? If a lathe, what do you mean by "feed lever?" Are you referring to the half-nut engagement lever? If so, I was under the impression that that should ONLY be used when threading. Or, is that only on a South Bend? Do other lathes operate differently?
