- May 7, 2015
- 269
You don't need a space block set to set an angle. Turn a piece of scrap to the desired diameter and verify with your mike. Part the piece to an appropriate length and place at one end of the vise with the end of the spacer touching the vise jaw and the cylindrical surface flush with the end of the vise jaw. A magnet helps to hold it in place. Lay your parallel with one end on the vise floor and the other on the cylinder. (If your vise jaw overhangs the floor of the vise, you will have to correct for that overhang.)
The relationship between the diameter of the gage pin, the width of the vise and the angle is: (D/2)/(W-D/2) = tan(a/2). If you let A = tan(a/2), then D/2 = A/(1+A) * W.
The drawing shows the geometry of the setup. With suitable care, very accurate angles can be set up.
Thanks RJSakowski, sounds like a lot cheaper method than purchasing as set of space blocks.
Joe
