After several years of putting up with the Zexel rotary pump(no fuel on cranking) on my Bobcat, I ordered a brand new
pump on E-Bay. The new pump would not run at all but would make smoke so I knew it was a timing problem.
To determine where to mesh the gears, I hooked up the pump to the fuel and turned on the switch to open the
solenoid. Turning the pump by hand told me the pump direction was correct and also where to install it since
it would dispense a drip of oil on the #1 cylinder as it was turned counter clockwise. After that it ran to a fashion.
Then using my home made timing tool, I set the timing properly and it now starts and runs perfectly.
I absolutely refused to take my original pump back to the place that supposedly overhauled the pump for $500
and I got only about 200 hours use from it. Not only that, the pump shop is a hundred miles from here.
So now in my spare time I can take a look at the old pump and see why it won't start. I think the problem is that
the governor is sticky and not giving any fuel on startup. The brand new pump was only $480!
After all the work I have done on diesel pumps lately, I feel confident that I can take it apart to get to the bottom of it all.
The old Bobcat now purrs like a kitten, starts with no argument.
