Last week was the first time I had a chance to use my new V-Block Set, a gift from my wife. I w as attempting to hold a length of 1-inch alum. round stock prior to milling a flat. The V-Blocks in this set, include a U-Shaped "yolk" that is used to hold the stock in place. After placing the alum. in the "V" I threaded the holder finger tight in the block. Then I positioned the block on the table u sing the X-Y adjusters and indicated the center line of my stock. I used a short piece of drill rod (there is a hole in the knurled thumb nut portion of the screw) to snug up the threaded holding screw on the yolk and the yolk promptly broke in half. I want to emphasize that the snugging was just a bit more than finger tight - any less and my material would surely have moved as soon as the end mill touched it. See photos below. If you look closely, the material is surely die cast mystery metal with a narrow cross section. It broke exactly at the weakest point . Did I do something wrong or is this a poor design? I called Fowler and they are "looking into it". I'm asking because I'm an amateur at shop techniques but my engineering background tells me that there should have been a more generous cross section at the drilled hole or stronger material.
Your comments are welcome.
Best regards, Frank
View attachment 224728 View attachment 224729 View attachment 224730
