- Feb 28, 2019
- 535
Not really looking for answers here, just an observation and interested in comments.
Still getting to know my Tormach 770M. I had to make some small parts - a round base ~.500 dia with other features milled on one end. Pre-CNC, I would have turned the boss / round on my lathe and then held the part by the round end in a vise on my bench mill. I figured this would be a good opportunity to make a soft / AL jaw set for my fixture plate. One op to hold the raw bar stock and mill the final boss/round, flip over and do the non-round milling all on the CNC.
The round needs to fit pretty precisely in the hole it will end up in so I was trying to get the diameter as close as possible. I did a finish cut leaving .005 radial with the intention of then being able to measure and take one last cut to hit the target diameter.
In the process, I discovered that the diameters of the parts (I was making two, exact same model and tool parts for each) seemed to be off by .0015
Now let me be clear here - that's close enough for what I'm doing, but these are two identical circular bosses cut with the same brand new end mill on a very new machine.
When I finished them up and could pull them out of the soft jaws, I was able to take better measurements and determined that they were in fact damn near identical, they just happened to be not quite round! Back to my original motivation - I knew at the start that If I wanted perfect cylindrical parts for a tight fit in a reamed hole, that I'd be better off doing that on my lathe.
However, considering the extra milling on the other end of the part, they are also a good use of a CNC machine - just hold the round end and all the other steps can be done in one fixture rather than the fussing around it takes to do it on my manual mill.
So my experiment confirmed my suspicions - (maybe). I can get < .0005 error on small round parts on my lathe. Getting .0015 diameter error on a small round part on my CNC machine is acceptable as long as I'm aware of it (and if the actual required tolerance / fit is anywhere near that).
Just for fun, I drew up a diagram that exaggerates the error of 4 diameters I measured on both parts:
I'm guessing the error comes from either machine wind-up (lead screws), controller tracking (stepper motors) or backlash.
Interestingly the error is greater in the Y axis - which implies the physics of the machine are involved. I did a bunch of work with ultra-high precision XY stages for positioning micro-chips during lithography. Because the Y stage (typically) carries the X stage, it has significantly more mass (+2X) and hence is noticeably harder to accelerate.
Hope you found this interesting.
Finish cut was using a 3/8 3 Flute carbide end mill, 4000 RPM, 10 in/min
very slow.
Do you think I could get it more accurate? other than buying one of those really cool lath mill combo machines!
very slow.
