Stainless had the interesting property that you can make it rot at the boundary of water and air. Get a strip of stainless and leave it in a glass of water, with some sticking up above the water, and the rest below. Enjoy the spectacle of of a line of rust at the boundary. This happens with A2. I think A4 is more resistant to this phenomenon. The name of the process is "differential aeration".
I have also reduced "stainless" into rusty mush. It does take temperatures above 700C, and it having seen some calcium chloride salt. That stuff does not wash away completely, even if you use loads of water.
A word about stainless, and getting it wet with any chemicals. It has hexavalent chomium. That stuff is so unbelievably toxic that it's an outright hazard to us! Trying to use a stainless ex-chip fry tub as a vessel for electrolysis de-rusting, to also be one electrode, was a very bad idea!
[The curious can google "hexavalent chromium", and decide the most we should do with stainless is to machine it. If you start, use lube, cut deep enough, and don't stop on the way. If it rubs, the tool is immediately trashed from work hardening! ]
