- Mar 26, 2018
- 8,645
Hi gang,
I'm slowly refurbishing my 14" Delta/Rockwell saw. It's a 28-300.
I replaced the upper bearings. They were toast, what a difference.
I should have the new tires today. I installed new belts and I have a new blade.
I have the high speed and low speed working slick.
My question,
I haven't ran it yet after the new parts. I know old blades that have been on a saw for 20 years under tension are junk, I know the v-belts have a memory, they were just full of movement.
The vibration should be greatly improved but I have a lower wheel the has lateral run-out that is pretty severe.
I know it's going to contribute to vibration.
Is there any way of straightening these wheels?
Do I just replace it?
I have to figure out how to remove it. I took the LH threaded nut off but the keyed pulley is on there.
Heat it up and give it a wack?
I can't put a puller on the thin webbing.
Thanks for your ideas.
Jeff
My question,
Jeff
