Turcite is a plastic which combines acetal and silicone and used on wear surfaces in many applications, including lathe and mill ways. Delrin is a trade name for an acetal polymer. Delrin AF contains Teflon and is used for similar applications as Turcite
I have used both acetal and Delrin and can't honestly say that I noticed any difference in performance. For the purposes described above, either should work. They tend tend to have self lubricating properties which is why it is used for bearing surfaces. Delrin has a yield strength of between 6.5 and 9.6 Kpsi or about 30 to 45% that of bearing bronze. Delrin and acetal a common choices for gears. When I built the reversing banjo for my 602, I used acetal gears. Given the contact surface for a lead screw nut, I would expect good to excellent performance under conditions normally seen in a small lathe.
I have done a bit of thermal machining of Delrin. In one instance, we were looking at making a .009" hole in a 1" block. I used a length of wire connected to a power supply to "cut through the plastic much like a weighted string on a block of ice. The Delrin melted around the wire and the wire slowly moved to the center of the block with melted Delrin filling the path and freezing. The result was a wire embedded in a solid block of Delrin. When everything had cooled down I pulled the wire, leaving a .009" hole.
If using the above described method to form a lead screw, the Delrin will shrink as it solidifies which will result in an interference fit. Typically, a clearance fit in a screw /nut is obtained by modifying the basic pitch diameter. With the Delrin thermoformed nut, it will also be changing the thread pitch. This will amount to a preload which can be a good thing if it isn't so much as to prevent movement.
One word of caution when heating Delrin. It gives off some very obnoxious fumes if heated to too high a temperature which attack the eyes and mucus membranes so do so in a well ventilated room
Nice one RJ
Re :- The fumes , it also catches alight with a nigh on invisible flame & it sticks to your pinkies very well , even the tiniest burning splodge is agony ... guess how I found out ?
In the earlier post I mentioned using cheap digital thermometers fixed to the bar at the ends & a free one to check the middle to ensure you get an even quality melt .
If you heat the threaded bar to the melt point ( do a test on some scrap & scrap thread to find you thermoplastics melt point ) and use a square former (made from two sections of angle iron ) you can make melt nuts or other shaped parts for that matter of fact . I've been considering making a smooth aluminium cylinder with an aluminiun piston at each end in which I've taken out enough metal to make a cast form put in sufficent plastic ( by volume in water .... Eureka I've found it
) then use the heat method I've described & a vice to squeeze things up to produce repeatable parts Using my Dremel to grind /remove metal so as to get the forms I need in the soft aluminium piston faces.
Reading the post about turning a single point thread , I've seen a set of quality Acme taps available at the cost of an arm & a leg too .
Would either way work well on a 3/8 internal acme screw thread ?
I can see it would be difficult for me to turn one up with my limited skills in such things , especially getting the tool cutting angles correct for an Acme thread .
However I've learnt to turn up a very accurate rectangular square block in the four jaw chuck out of all sorts irregular shaped rubbish /scrap . Perhaps putting a thermoformed nut on an acme thread & then turning it to a round rod between centers should allow me to use the cross slide to put a decent mounting flat along the cylindrical face & have it reasonably accurate when aligning / fitting things up .
Another thing might be buying a fairly thin walled acme phosphor bronze sleeve , knurl it a bit then thermo-form / embed it in the bigger part of the assembly ,
Ooooh , I'm spoilt for options & have so little time to play at doing them . Oh for a decent precision mill, lots of attachments & the space to put it .
