A "straight shank" dead center (meaning it is not hardened)? Isn't that also referred to as "bar stock"? After all, the point of it is that one can / does easily skim the tip every time it is used (depending on the desired accuracy). This is to correct for the normal - hopefully minimal - run out that is typical with a 3J chuck. Once skimmed, that center will be dead on to the inherent accuracy of the machine (until it is removed from the chuck).
