Welcome to the forum. We are a friendly bunch. Don't be afraid to ask any question no matter how simple you may think it is. You will get good answers to your questions.
Lathes are referred to by the distance between centers. Not bed length. For example my Craftsman lathe is a 12x36. The distance from the headstock to the end on the bed is just short of 47." The overall bed length on my lathe is 54." Beds are measured by the total length of the bed. Not from the headstock to the end of the bed. Based on what you have provided your lathe is probably a 12x30 or 12x24.
You should donate to the forum. That will give you access to the documents section. Well worth the nominal cost. I was making the annual donation and then realized that in a few years I would have donated the same amount as a life membership donation. So I paid the extra money and am now a life member.
Our resident expert should chime in here shortly and can answer all of your questions about your lathe.
I use mineral spirits in a spray bottle to keep my lathe clean. Different parts require different oils and grease for proper lubrication. The MOLO acronym for Manual of Lathe Operations is a must have. It will tell you how to maintain, setup and care for your lathe. It is available in the downloads section of the forum.
There are lots of good sources for learning how to use your lathe. IMHO Mr. Pete aka Tubalcain is the best of the best. He is a retired high school shop teacher and knows how to teach. If you haven't been to his you tube channel here is a link.
https://www.youtube.com/c/mrpete222/videos
