- Oct 15, 2013
- 314
Looking for helpful responses for what I've found on my Sheldon EXL lathe.
I found the end of the compound is bent downward, from previous crash/es into the chuck. Discovered when a new t-nut would not fit the slot. Disassembly made it obvious!
The bend begins by the pen in 3rd pic. But after cleaning l found a crack on both sides, even with the front surface of the T slot (just forward of that pen).
I expect the top of the compound cannot be flat.
So... Do l remedy it, or use it? Flatten by pressing? Mill a skim cut to flatten the 'ways' and the top surface?
Thanks!
Thanks!
