Well it took a fair bit of "grunt work" work and patience to get there, but the input adapter was finally ready for the hub:
I knurled the hub shoulder in order to give it a little more "bite" once the hub was shrunk on there. I had .0005 - .001 before the knurling, .0025 after knurling. I reduced that down to 0.002 by giving it a little polish with some 600 grit, which probably just knocked off some of the extraneous sharp bits from the knurling process that was messing with me being able to get an accurate measurement.
Then the hub went into the oven to soak at 500f for 20 mins:
I wrap all my heated parts in tin foil for the heat soak. Occupational habit. When I'm building jet engines and fitting something like a #2 engine bearing, we always wrap it in foil to try and keep it as hot as possible on the trip from the oven to the compressor stand.
One last check of the input adapter to make sure it's microscopic clean (IE: nothing to hang or cock the hub when it goes on) and then the foot race from the oven to drop the hub down on the adapter:
Nice. Slams right home on the shoulder of the adapter. You can't get a .001 feeler gauge under it:
I'd normally do what we call "drop measurements" to make sure it's fully home, but it's more than good enough as it is for this application. No light under the adapter works for me!
Once cooled, that sucker is locked on there and no cracks in the cast aluminum hub.
Then I assembled the rest of the sprocket drive adapter:
and slid it on the transmission input shaft:
Perfect!
Now it's just make a spacer to take up the remaining shaft you see in the video to the inside shoulder. Mostly for a finished appearance as much as anything else. It will also be used to help retain the sprocket carrier in the cush drive, a wider shoulder at the sprocket carrier end of the spacer will handle that chore. Easy stuff!
Gotta say, I'm pretty pleased with how it all turned out. Took me quite a while to get it done, but that's what happens when you are designing and prototyping at the same time I guess. I shudder to think how much it would have cost to have a shop build this for me! It's not finished yet, but the hard/critical work is now done!
