- Feb 1, 2015
- 9,992
Releasing the half nuts and reengaging on any identical thread dial position won't work.When cutting metric threads on a lathe with an imperial lead screw you are always told you can't disengage the half nuts and you have to reverse the lathe leadscrew to move the carriage/tool back to the start for the next pass.
I was thinking (that can be dangerous), what if you set a carriage stop to the right of the carriage just before the start of the thread so that you were always bringing the carriage back to the same start position, and always reengaged the half nuts on the exact same position on the thread dial?
My lead screw is 8TPI and my thread dial has 8 indication marks, so if always engaged on the same number (say 1), and the carriage was always in the same position due to the stop I had set, wouldn't I be ensuring I was always re-enggaged onto the same position on the leadscrew and could do away with all this reversing the lathe hassle?
I'm away from home for work at the moment or I would of just gone out to the garage and tried it to see if it worked.
It works for inch threads on an inch lathe because the thread dial is timed to the lead screw by the number of teeth on the thread dial. For instance, if you have an 8 tpi lead screw and the the thread dial gear has 32 teeth, the dial will make one complete revolution in four inches of carriage travel. If you are cutting an integral number of threads per inch, and you move exactly 4 inches to bring you to the same position on the thread dial, you are still engaging in the same position relative to the prior pass.
A metric thread doesn't have this nice integral relationship with the lead screw. Moving 4 inches is 101.6mm. You have to reengage at exactly the same spot on the lead screw. This is why Tom Lipton's method works. He disengages the half nuts and immediately shuts the lathe off. The spindle coasts to a stop. He then reverses the spindle and reengages when hits the same dial position. He continues in reverse until he is past the start of his thread, shuts the lathe off, and advances the cutter for the next pass.
Another approach would be to start at the shoulder and thread towards the tailstock. The lead screw direction would be reversed and you would need to either flip the cutter upside down or thread from the back side of the lathe. Joe Pieczynski has a good You Tube video on this technique.
