- Oct 21, 2014
- 2,162
You need to learn how to grind the tools to fit the job, I have purchased an extra set of HSS blanks that I grind, to make some, Plus I even took broken drill bits and made some, I just did a wobbler with a flywheel like what you are talking about, At the time I did not have a boring bar etc. But took the back end of a bit I liked and ground it to do what I wanted. Now I can do two different cuts just by flipping it around.
One of the other things I did is work part of it from inside (hub) out then was able to work the area left to the rim will less material to have to work. Again, don't be afraid to grind what you need. I have found that some of the ones I bought did not work as well as what I ground and finished by hand. Depending on the quality and how they finished them, you may be better redoing them. There are plenty of places on the web, and You Tub on grinding them. Good luck. It will take time but We all can do it if we try.
KVT
KVT
