- Apr 29, 2019
- 2,252
What RJ said.
Using a Dremel and a cut off wheel will leave a radius in the bottom of the groove. Even with a tool post grinder it will be had to keep the corners square.
A radius in the bottom of the grove will allow the ring to easily pop off under load. It is surprising just how small of a radius can make the ring pop off. The sides of the groove MUST also be perfectly perpendicular to the axis of the the shaft. otherwise it is a ramp that will allow the ring to come off. Where I work we were having an issue with rings popping off under load. It took a magnifying glass to find the radius in the bottom of the groove. They sharpened the tool and all was good again.
Your best bet will be a carbide parting or grooving tool of the correct width with the sharpest corners possible.
