Thank You All For Helping And For Sharing Your Advice! I very much appreciate your guidance, suggestions and safety considerations, plus the links.
I also appreciate the advice about going slowly and using lubricant. At work, sometimes the guys would cut aluminum plate or bar stock. The ends of the cuts always had thick beads of melted metal. But I don't recall them ever using lubricant or going particularily slowly.
The miter saw or table saw sound like the best plan with the tools that I own. I like the sled mention from David2011.
I've two miter saws. One is an old Ryobi that someone trashed. It's not terribly repeatable. The other is a Bosch 12". Perhaps I'll pick up a fine tooth, non-ferrous blade if one exists. The challenge is the 1" arbor hole.
The table saw does not have a narrow kerf insert, so I'm not sure if the wide opening in the factory insert is a good thing or detrimental.
Jimsher asked if I had a mill, lathe or 5C collet. I do have a South Bend 13" lathes, but no mill & no collets for the lathe.
RWM mentioned rough cutting & finishing on a disc sander. That sounds like the safest way to be accurate. (Accuracy tolerance is large, perhaps 1/16".) Although I don't own one, it might be a wise investment for this and many other projects. I've often wished I had a disc sander or a vertical belt sander.
Paul
