You at least need to get a PROPER metal cutting blade. They have NEGATIVE RAKE-the teeth lean backwards a little. That keeps them from breaking off. Special metal cutting Skil type saws run a bit slower than the ordinary higher speed wood cutting saws.
There are lots of hot chips popping around every where,and this is NOT a procedure I would recommend to novices.
It is certainly NOT a good idea to use an under powered table saw,thinking it has a built in safety factor. If a capacitor motor slows down,the capacitor kicks in,rapidly accelerating the speed of the motor. This can be very dangerous,and causes kick backs.
I bought a special metal cutting saw,a Milwaukee,I think,and a special metal cutting blade. I cut up a 1/2" sheet of bronze that was 4' x 8'. I used a wooden fence clamped to the plate to guide the saw. You do not want to get your saw cocked at a little in a cut in the cut. It will kick back. Even with the special housing,which covered the whole blade,plenty of blue hot chips bounced around. A face shield is certainly called for. Long sleeves are good also. You do not want to be distracted by hot chips on your arms.
I sold the saw to a forum member when I was done with it. Sawing metal with a circular saw is not something I want to do. The plate weighed 800#,so I had to cut it into smaller pieces to even get them light enough to get onto a machine. Further cuts can be made on my Roll In bandsaw.
