Cutting a keyway the hard way.
@mikey so instead of a dill bit then clean up with a file, you're saying just use an end mill, leave it round at the top where the keyway meets the pulley's keyway?
You're a moderator around here? I think you need to write an 1500 word essay why we don't do that around here...
Yes, that's exactly what I'm saying. I've done it like that and had no issues. For a pulley, the key simply resists rotation; the pulley is held to the shaft by one or two set screws. The precise shape of the keyway in the pulley doesn't matter and a keyway with a rounded top will not significantly reduce strength so why not make it easy on yourself? The proper tool is a broach but not all of us have a broach ...
That is so me, to short cut it...trying to turn over a new leaf....this week maybe two? Anyway, I don't know if anyone would be proud, but I am in the process of making a broach. Will post pictures, but only because I'm proud of not lazy-butting it on this, unless I screw the pooch, then I was just joking, I really didn't try to make a broach.
There are many ways to cut an internal keyway. For steel, I use a broach or take the time to set up the shaper. For aluminium and brass, being softer metals, I have often used two or three hacksaw blades tied together and roughing in the cut. Then finishing with a three square file. Broaches work well, if the keyway is a size I have on hand. I don't have any metrics.
An end mill works quite well most times. Stiffer than a twist drill, it will be less likely to run off center. But for speed when I'm in a hurry, the hacksaw blades do the trick. And are a lot easier to find in the field for a "portable" job. For aluminium, a few wraps of good electrical tape will do the job for holding them together and as a "handle". It won't last long, but long enough.
So, it will work...but I enjoyed the experience. Just doing aluminum, didn’t know I had an option besides a $500 broaching set. Probably will make this again & try a little harder watching the details. Thanks for the directions guys!
@Buffalo21 I will give you $60 plus shipping for your set.
Are we talking the sets with the cutting teeth on a long rod and you continually add more shims? That was all I was aware of until someone(s) pointed me to the videos. At any rate, I don't have an arbor big enough for those and my shop press would take days. How this one works? We'll see. I suspect good on aluminum.
I don't know what brand that is but..
MSC $350-$450
Broach
Still 2-$300 on Shars, I believe you got yourself a very good deal. Hopefully after these 2 pulleys, I won't need one for some time
