This was an experiment but it worked out so well I thought I'd share it. Knowing the profile would not be perfect I used aluminum. Grinding wheel was 1/8" thick, worn just about right. I had to make a keyway on the shaft as the aluminum would not stay on tight with a friction fit only.
Here are the full size pics:
http://s1182.photobucket.com/albums/x445/martik777/Backgear repair/
