- Jun 22, 2015
- 68
Here's a tool post I made for my Logan 200 lathe. The AXA post I have has the capacity for a 1/2" cutoff blade and I was hoping a 3/4" blade would be more rigid. The post works but really no better than the 1/2 blade on the AXA post. Does anyone have any suggestions for as to how to stop a tremendous amount of chatter? I've tried high speed and the slowest speeds. The slowest is by far the best but still not great. I also checked the bearing in my head stock... as near as I can tell I have about .001 slop in the bearing which doesn't seem excessive to me.
I suspect I'm expecting a bit to much from a small lathe. The compound is nowhere near as solid and other lathes and the 1.5" head stock probably flexes under load. Still I'm hoping somebody has a good suggestion as to how to improve the chatter I'm getting. Thanks.
