- Jan 1, 2011
- 305
I often drill a series of closely spaced holes slightly away from the final desired opening. This reduces the tool forces on the cutter used to clean up the opening. This approach reduces the clamp-down pressure required to hold the thin metal.
Absolutely! I'd "chain drill" it without a second thought, especially if it were a bigger hole.
Usually, for tough stuff, I'll chain drill on the mill, take it off, and chew out the pieces between the holes by plunging or whatever with an old, dead end mill I save for that kind of destruction derby. Or, I'll drill the holes, take the part off the mill, break out some bits and feed a hacksaw blade through it, and cut the piece out by hand before sticking it back on the mill for finishing the cut.
