I have an Atlas 10100 Mk.2 6"x18" and am very happy with it. As long as you work within it's performance envelope it does fine work, or has for me anyway. Recently upgraded the plastic gibs that it came with to steel gibs & it seems a bit more accurate. Only a few things that it doesn't have that I'd like to see, like QCGB & power cross feed for facing off material. Don't try taking very deep cuts and take your time working with it and it will produce the pieces you want/need. I was looking at lower cost import machines when I came across mine, metal gears VS. plastic, larger length between centers, lower cost for a better bargain as I saw it. LMS supports them with pre-ground tool bits & parts can be found on ebay fairly frequently. If you can find one in great condition I say go for it.
