- Aug 20, 2024
- 6
I picked up a used King Industrial 10x22 lathe (same as Grizzly G0602 I believe). The cross slide was stuck. I took it apart, and the nut is actually stuck on the lead screw. I managed, with great effort to get it off, but it was almost impossible to remove. Any idea what would cause this or the fix? The lead screw looks ok to me, each end of the nut threads on easily, but once you get about 3/4 of the way it get's tight and then eventually so tight you can't turn it at all any more. Can that be fixed or do I need to order parts?
Thanks!
Thanks!
