- Nov 24, 2017
- 64
Update,
I took a .025” cut across my work piece and measured the step with a micrometer.
It was only about .003”. It just felt like more when measuring with my fingernail
I then took a .005” cut and there was no step at all.
After some head scratching I concluded the cross slide (and work piece) is moving away from the tool towards the latter part of the cut and therefore the front of the work piece is swinging inwards torwards the tool causing the trailing cut.
It actually doesn’t sound too bad (no clackity clack) and the finish is reasonable.
From this I conclude the problem is simply a worn cross slide.
For the accuracy I require for my small hobby jobs I’ll probably work with it.
Thanks for all your comments.
David
David
