- Nov 24, 2017
- 64
Hi Guys,
I have a 10” Atlas lathe will a milling attachment.
I had a fly cutter in the spindle, when taking a standard flat cut across a piece of metal in the vice I noticed the back rotation of the tool was taking a significant trailing cut. The tool was set at about a 3” diameter. From this I deduce that the spindle isn’t at 90 degrees to the crosslide.
Is this adjustable at all?
I have not removed the head from the bed since I have owned it but who knows what has happened in the past.
I suppose I could take a facing cut across a workpiece in the chuck then run a dial indicator across the full face and see what it reads.
Or should I just ignore it?
David
David
