- Oct 31, 2016
- 2,720
Was finally able to get back to working on the post for the norman style qctp that I am making. The piece of mystery steel that I am making the post out had an approximate 1/2" hole in it which I needed to enlarge to 5/8". That's .125" and because each pass will take 2 times the amount of the cut I figure that I will be moving the cross feed a total distance of .0625." I thought that I had read somewhere that on craftsman 12 lathes the cross feed dial gives the actual distance that the cross feed moves whereas on some lathes the dial gives the amount that the workpiece is reduced in diameter or in my case how much the diameter of a hole is increased.
I am merrily working away and as I get close to a total movement of .0625 on the dial I am not anywhere near 5/8" diameter for the hole. By the time my 5/8" bolt will fit in the hole the cross feed dial has moved a total of .115. A little over one complete revolution of the dial. I have always had trouble accurately turning a workpiece or boring a hole to a certain diameter on my lathe.
So is the cross feed dial on my craftsman 12 lathe supposed to read the distance that the cross feed actually moves or as I found out today the amount that the workpiece changes in diameter?
