- Sep 28, 2013
- 4,413
good tip on the belt traction spray, I never even thought of that. There's a TS down the road so I'll go check it out at the weekend.
The carbide bits were a Christmas present before I got a bench grinder and stones to make my own bits, but I don't use them much any more. They're handy for alu sometimes as they break the chips nicely, but that's about it.
As for the lathe, it's not much but it's better than nothing! Thread cutting = taps'n'dies I have seen a trick that Taig and Sherline users use which is to drill and tap a hole with the thread pitch you want in the piece you want to thread, then chuck that bolt in the tail stock and thread it into the piece. Then, you leave the compound just shy of snug, so that it'll move and push the tailstock up against the compound. Turning the piece screws the rod in, which pulls the tail stock and therefore the compound towards the chuck. Never tried it as I've had no need yet, but it's an interesting option.
Yes, that large pulley does run on that old crack crappy rubber wheel on the motor shaft. Yes, it's not a good idea and I'd love to put a pulley and belt on there at some point, but I haven't yet figured out a simple way of tensioning the belt if I do. Reversing the motor = swapping the wires around on the motor with some knowledgeable advice I presume? I'd also really like to replace the countershaft (if that's the word) with a new shaft and ball bearings, as it's worn where the shaft runs on the outer bronze bearing and makes a fair bit of noise. Lots of projects, very little time! No idea on the shaft size (1/2in?) but I can measure it tonight. Making a pulley would be theoretically simple
