- Jan 15, 2013
- 171
I currently run a hp treadmill motor on my 109 it works very will, I also run a 2 hp on my mill drill. I feed them both off of the same speed control and tach. the control selects which machine i'm running and forward or reverse. I can also look at either machine from the tach.
If you look at the treadmill or any dc motor the rpm normally is way higher then a induction AC motor. so when you are running at the same speeds as a AC motor the delivered HP is far less. For example at full speed my lathe motor turns 4800 Rpm and draws 19 amps AT 90 Volts That is 1700 whats and 2.28 hp. but at 1200 rpm the current is 9 amps at 35 volts .425 hp and 300+ watts. most of my usage on the lathe is less then 1500 rpm and when i'm in back gears for threading and die work i rarely run it above 1000 rpm so that 2 hp motor is realy working at about 1/4 to 1/3 hp and ideal for a 6 or 7" lathe.
The real advantage i have found is on the mill in that i can power tap and not worry about breaking taps off because it just stalls the motor if the tap bottoms, on aluminum it will tap through anything up to about 5/8" on steel it will bind and I just reverse it and go again . on a 1/2 hole 3/4" deep it might stop twice . Full variable speed is also a great big advantage.
My mill drill is a fully modified 17" drill press with angular contact bearings and gibbs on the spindle, a fine feed on the spindle and Gibbs on the column. It also has a powered Z axis of 7" + the spindle travel of 4" this gives me 11" Z axes travel I use ER25 Collets and a lock pin on the MT2 adapter. The X Y Table is one from about 25 years ago and not asian made. I have about 225.00 in the mill, A good functional light mill drill can be made from a large drill press if all the issues are addressed.
Art
Art
