- Dec 12, 2021
- 84
vtcnc: I checked (RE: Mx-head photo) which you ID as Dunlap, the apron that is normally seen on the headstock was ground off. After inspecting the head stock on the other machine, the spindle shaft is worn out. I'm speculating that the owners were hacking the Dunlap headstock to either put it on the Atlas made machine or make it work on the double V bed. One other thing, I measured the spacing on the double V bed and it is 2.15" and it is quite long. On Ebay, I can see the apron on some machines that you refer to. It is integrated into carriage gear mechanism which is missing on either my headstock or bed. I need a few days to sort all this out.RE: Mx photo…
I don’t think that is a Dunlap bed, the Model 80 had sort of like an apron that went to the bench top. No real space to pass through underneath the bed. With that said you may have at the very least a good bed to make up a nice center for checking runout and concentricity of your parts.
RE: Mx-head photo…
Definitely looks like a Dunlap headstock to me. I had one for years and everything at least looks the same to me.
Spajo
