i'm not proud to admit, but i have sinned it seems.
i have welded multiple pressure vessels for friends as well as Getnr' Done NOW in Business
I worked for a drayage company for a little while as a diesel mechanic.
As soon as the Brass found out i could weld...tag!!!
i got every rusted, crusted, frozen, broken, mangled piece of excrement they could throw at me.
i welded tanks of all sorts for them, even did my own crude caged pressure testing.
we had a tank for checking newly repaired truck tires, i'd sink the tank when i could and take em up to pressure in steps.
i learned it was best to drill the ends of the cracks, weld the cracks, grind flush and then weld large patches whenever possible to maximize the weld surface area around the repair you just made, to prevent it coming back.
yes, the process was slow, dirty,and time consuming. but i had a 100% success rate.
must have been doin' something right or wrong dependent on your perspective.
