- Aug 15, 2013
- 2,520
I have only done a couple of countersinks, but here is how I avoided all the math. I’m open to better methods.
Once you have your hole drilled or threaded, drop or thread your screw into the hole as far as it will go. Then lower the spindle to touch your countersink bit to the flat part of the top of the screw and zero the Z-axis readout. Then move over and touch the bit to the top of the work piece. Note the reading. Remove the screw from the hole and realign the bit directly over the hole. Now lower the bit until it touches the rim of the hole. The point of the bit will be below the work surface. Hold it there and zero the Z-axis readout. Now drill the countersink until the Z-axis readout matches what you noted earlier. The screw should now fit flush with the work surface.
Tom
Tom
