- Jan 16, 2017
- 216
Hi guys,
Something I've struggled with since last year has returned. I use it at work all of the time, but for some reason the formula doesn't want to stick with me.
Say I drill a hole with a 3/8" drill and the print calls out for a .425 diameter hole chamfer on it. I understand I need to use a 1/2" countersink, but I struggle with grasping how deep I need to go on the hole.
I also understand how 82,90, 118 included angles all make a difference in the calculation. I know that 90 degrees is the easiest to figure out because you divide it by 2, but then I get lost again. I've had many people explain it to me, but I was wondering if any of you had a quick and easy method to make it stick. I appreciate your help!
82 and 90 deg. are about 99% of what I do so if you could explain both of those it'd be awesome.
