- Dec 25, 2011
- 10,552
The point that I was trying to make was that not all bronze bushings sold by any hardware are going to be sintered bronze. I added the word "brass" because most people can't tell the difference and many bushings are actually made of brass, although relatively few of them are sintered. If you take a solid bronze bushing (many are used in marine applications) and soak it in oil you'll just get an oily bushing until you wipe it off.
You were, however, correct that Oilite was a Chrysler division or department. However, the bushings weren't developed soley for water pumps. Of the six typically found in a last century automobile engine, only one is in the water pump. And I said nothing about Atlas or Clausing having anything to do with inventing the sintered bronze bushing. They didn't invent it and didn't invent Zamak.
On another subject, resizing the bore, you have to be careful how you do that. The worst way to do it is by grinding (or honing). Grinding will smear the ID surface and close off most of the pores. According to the bushing manufacturers, the best way is with a VERY sharp single point tool. They say further that reaming may work but only if the reamer is extremely sharp. My take is that if you needed two little bushings, you're better off paying a little more for ones that are the right size to begin with. I have better things to do than spending four hours saving four dollars on two bushings.
Plus as was hinted at just below, the fact of the matter is that we all have a vested interest in keeping Clausing interested enough to keep supplying parts for our old Atlas machines. The parts that we could buy somewhere else more cheaply and modify to make sorta fit wouldn't cost us much more if we bought them from Clausing. The ones that can't be bought cheap and modified will eventually shut down every one of our machines or leave us with the only options of paying top dollar on eBay for a used part or buying another machine and hoping that that part is still good in it if Clausing finally says the Hell with it and shuts down their old parts department. I went through the same problems caused by the same shortsighted attitudes in the 1970's and 1980's with Land Rover parts in the US. The only thing that would have kept me going if the two US independent vendors had shut down was that I sometimes had to go to England on business. That wouldn't be an option with Atlas parts as they aren't being made anywhere else.
Robert D.
Robert D.
That all sounds good but I respectfully disagree I never told him to use brass,,, powdered cast bronze and there so called sintered bronze is the samething powdered cast bronze that they sell in any hardware store is porous and will hold oil even if it did not which it will it will work fine. As far as heating them up and droppping them in oil it works fine and originally that is how they where made they just did not grow on trees the process was originally developed by Chrysler corp for water pump bearings in the 20's high tech.... hardly. I made them for 25 yrs when we made busings either that or we would use a vacuum chamber and 30 weight oil. Either way it is how it is done it was no engineering miricle that only Atlas or Clausing come up,, with most of there prices are triple what they should be there just raping the public because they can all of the busings are of common size Clausing just buys them off the shelf and repacks them. And BTW the ones I made for mine 25 yrs ago are still there and doing fine on my recent rebuild and mod. they nor the shafts needed to be replaced I think that is proof enough.. Ray
