The bearings in the countershaft of my 10107403 lathe are pretty shot. Additionally, I expected them to have a small hole in them, allowing for the oil added to the two oil cups on the casting that holds the countershaft spindle to drain down and lubricate the shaft itself. The parts list shows part number L3-109.
Sears sells these bushings for $23/ea.
Here are my questions...
1. Should these bushings have weep holes for oil from the oils cups to pass through?
2. Are there other sources/options for these bushings?
3. Can I turn them out of something and replace them? If so what should the dimensions be and should I put a small hole for oil in them?
