So this has happened a couple of times now and I feel like I have to be missing something. Drilled and reamed a hole. Didn't have a counter bore the right size, so I used a boring head. Seems simple enough. I ended up offset by maybe 20 thou.
X and Y were locked and the DRO showed no movement. I did move the table up. That's never caused a problem before, but I should double check that. Perhaps hold something round in the vise and use an indicator to center it, move the table, and indicate again?
Drill chuck is an Albrecht with a good brand arbor. Boring head is a Criterion DBL-202 with a straight arbor in a R8 collet. Mill is a Bridgeport.
At the moment, I'm leaning towards me doing something dumb, but might as well test that I don't have a crooked arbor or something. Never know. I'd appreciate thoughts on things I can check to see if something needs to be fixed, or ideas for things I might be doing wrong.
