With my Phase II 4 jaw, no two jaws were the same. Some had more taper than the others. The idea of starting off with a slight taper makes sense but it bothered me that no two jaws were ground the same. So I ground them more uniform on the lathe and removed the taper.
The radius of the curvature on the jaw pads was determined by how far apart the jaws were when grinding but had to be smaller than the through hole as you mentioned.
