- Feb 1, 2015
- 9,983
Here's a question for the group. What is the correct geometry for a 4 jaw chuck jaw?
When I bought my Grizzly G0602 lathe, it came with an 8" 4 jaw chuck. Some time ago, I mounted a test bar in the chuck and adjusted it for zero runout at the jaws. When I checked the runout about 8" out it was rather significant so I set the chuck aside, figuring a poor grind on the jaws.
A recent resurfacing of a video regarding truing the jaws on a 4 jaw chuck got me down in the shop to look closely at the jaws. What I found is this. If I held a test pin by two opposing jaws, the front of the jaws would grip the pin but the back of the jaws didn't touch the pin. In fact, I could move the pin through several degrees of arc in a plane perpendicular to a plane through the center of the jaws.
I then mounted a .300" gage pin in the first section of the jaws and found that I could fit a .314" gage pin between the last section of the jaws.
I have seen several references to having a slight taper to the jaw grind to account for deflection of the jaws when loaded but this seems excessive. Here is a depiction of the condition. The angle has been exaggerated to illustrate the problem. The second picture shows the widening of the gripping surface towards the back of the jaw, consistent with a tapered surface. This drawing reflects the actual measured angle.
Checking further, I went to several machine vendor sites sites selling chucks to see if this was common. On the Shars site and the CDCO site, their 4 jaw chucks appeared to have the same taper. I wasn't able to find any clear pictures of name brand chucks to compare.
In thinking about it, when adjusting work for zero runout in a 4 jaw chuck, one would first adjust the jaws with the indicator close to the chuck and then move out some distance from the chuck and check runout. If there was runout, a few judicious taps would make a correction. Then move back to the chuck and repeat. Having the ability to pivot would assist this process.
So again, what is the correct grind for the jaw? Should it be ground so when it has a load, the jaw surface is parallel to the spindle axis or should the jaw surface be ground so the work is free to move slightly at the rear of the jaws?
