Stan,
Take a close look at the base of the gooseneck lamp fixture. There's a PVC braided air tube (supplied with the unit) that's simply connected to a 90 PSI shop air supply. It's just laying in the chip pan. On the blue magnetic base of the kool mist is a gang valve with a knob that controls air pressure inside the unit. The other hose connected to the gang valve runs into the storage bottle. Flow volume is adjusted with the brass ejection nozzle. Simple as that. I use the knob on the unit to turn it on & off but, I'll probably put an inline air switch for ease of use and so I don't wear-out any rubber O-rings and such inside the unit.
If you get one of these things, the hoses do not have air couplers to connect shop air. You must supply those... -A few bucks at Harbor Freight.
Ray
Ray
Ray I see you have a pretty simple setup. Where do you add the air. I don't see it in the photo. I was thinking of getting a small parts washer tank and using it as a flood cooler and just place it under the end of the mill table to collect the runoff. After seeing your setup I think I will try a mist cooler but there is no place to go here to see how they are put together. Could you put some more photos on to show this simple setup. Thanks Stan
