Don't know, Bruce. I didn't look too closely at the generated code, but I do know that so-called "artificial intelligence" is really artificial (as in shallow) and not so intelligent. It needs lots of hand holding. For instance, it set the units to mm for a problem specified in inches, then used the inch to specify movements. Also, I didn't specify a clearance height, or depth to drill. If this thing were truly intelligent, it would ask for clarification.
But, it's a good start, as it beats a search engine and then having to piece together examples. It is supposed to be "conversational", so I'm betting the output would get better if I (for example) said, "Could you modify that to use inches, and drill to a depth of 1"?"
Offtopic: Having worked with NLU (natural language understanding) for several years now, I can tell you that this is as good as it gets for "AI", and as good as it will ever get. The computer isn't intelligent, and has no concept of machining or any understanding of what you are doing with the information it is giving you. It never asks itself, "What is the user trying to do with this information?", "How will it be used?", "What will be the result of them accepting the information I give them?"
When asked a question, a human, without ever really consider that he's doing it, will extrapolate out from the answer they give to some end result. That's the true essence of intelligence. NLU should really be called NLI (natural language interface), because it is just a fancy way to get directions from the user into the computer, very much like moving a mouse to click a graphical element on the screen.
