- Aug 20, 2024
- 29
So I finally have my VFD working on my lathe, but I'd like to be able to monitor ALL the pertinent data at one time on one display. I'm running a TECO-Westinghouse L 510 VFD, it has an RJ485 port and I know I can get a cable to connect that via USB to a computer. But I have NO idea how to make the two devices talk to each other. My goal here is just monitoring what's going on, I'm quite content to set/change parameters from the VFD keypad. I currently have my VFD set up to show frequency, output current and voltage, and DC bus voltage, but I can only SEE one item at a time, I'd like to have a display that shows ALL that data at the same time. I don't mind adding additional hardware, and although not much of a programmer, I can muddle my way through an Arduino sketch if necessary. Thanks!
Dave
Dave
