Yes. Eight of the twelve 12" pre-war model all had babbit bearings, 101.07360...07363 and 101.07380...07383. The four with Timken bearings were 101.07400...07403. The first two models with QCGB were 101.27430 & 27440. Both are the same as the 101.07403 except for the QCGB. The last babbit headstock model was the 101.07383 made circa 1945.
Note that the 101.21450 gear box can be retrofitted to all 12 of the pre-war change gear models. So check first for nameplate (model number). If the model number is 101.07403 (which would be a conversion), 27430 or 27440, and if the machine is overall in good condition including low wear, it is worth an easy $700 in most of the country. The steady rest itself is worth $100-$150. The chucks, it would depend upon details.
One other explanatory comment - Up through the 101.07403, the model numbers did not define the bed length or distance between centers. With the 101.07383 and 101.07403, there were four catalog numbers for each model that specified the bed length. The bed length of the other ten models isn't specified in either the model or the catalog number. So if someone says that they have a 101.07403, that only narrows it down to four possibilities. Beginning around 1948, Atlas dropped production of the 18" and 30" between centers models. From the introduction of the QCGB equipped 101.27430 (12x24) and 101.07440 (12x36) on through end of production in March, 1981, the model number defines everything about the machine.
