My Tormach 1100 has X/Y/Z travels of 18"/9.5"/16.25", table is 34" x 9.5". My Bridgeport has a 9" x 42" table with X travel of 24", think the Y is at least 12". Yes, wish the Tormach had a little more though I haven't done anything to exceed it yet. Guys have replaced the Y axis ball screw and some other work to get the Y axis up to 11".
My Tormach has an 8" 4th axis. I've used it for a couple of jobs, most intricate was cutting some helical gears. It came with the mill; if I was doing it from start I'd go with a 6" super-spacer 4th axis. There are a couple of problems with Tormach's 4th axis. One, the regular 4th has the motor on LH side of the rotary table as viewed from the front. That puts the 4th on the LH side of the table. They recommend NOT using the automatic tool changer as clearance is a problem. The super-spacer version has the motor on the opposite side so it mounts on the RH side of the table; ATC is still usable. Another plus for the super-spacer is the head rotates like a dividing head. To cut the helical gears, I mounted the 4th on a tilt table which took it even higher.
If you go with a BP type mill you'll get really nice travels. The Centroid Acorn board is a nice upgrade for older controllers and gives you a 4th axis port. It also will control a VFD so you have spindle control.
Bruce
