- Dec 8, 2015
- 127
Hi. I purchased a Delta M series VFD (2HP) and want to hook up a remote potentiometer. The manual does not specify any specs for the potentiometer itself, but the specs for the AVI terminal say:
Impedance: 20k Ohm
Resolution: 10 bits
Range: 0~10Vdc = 0~Max.Output Frequency
On YouTube -one video shows using a 5K Ohm for this model, but in the comments he says use a 1 K Ohm. Another forum answer said 2.5 K Ohm. Can I determine what is correct from the Delta listed specifications? Is the 20 K ohm shown in the specs a maximum value allowed for that connection? Or does that indicate a 20K Ohm pot?
Thank you for any help.
Impedance: 20k Ohm
Resolution: 10 bits
