Re: Compound on Otpimum 180X300 Vario does not rotate. Is it possible to do a aftermarket modificati
Thank you so much sssfox and Billy, I must say I am very surprised by how helpful and gentile you have been.
I have found them and it works.... but its not practical, tough.
Any one knows of any modification that I can do/add to have the angles marked and to easily lock the compound after a new angle has been set?
Best regards
Try retracting the compound slide as far as you can.
It appears that there are two socket head cap screws on the base that allow you to rotate it, but you can't get to them unless you retract the slide.
I found them in the parts list, but the manual I found is in Spanish and I don't read Spanish.
Best regards
