- Feb 25, 2021
- 3,271
Pondering while reading this:
I will build a stand so accessing both sides is feasible. I prefer to keep benches clear. The table for the disc is definitely a compromise, as @keeena noted with asymmetric support. I guess a disc would be useful for slightly larger faces if you are trying to maintain a somewhat flat face, thinking of sanding the faces of a 4x4” cube. Not sure how much of that kind of work I’d encounter.
The other thing that just occurred to me is that a disc could use a guard as it will probably otherwise spray grindings in a big arc.
I think I’ll incorporate the mounting collar for the disc table when I build the central part, but otherwise leave the disc unbuilt. I can easily add it later, just make the necessary parts.
