Any suggestions on where to find the BS9 boring head arbor with a 1 1/2-18 thread? Any other economical suggestions? I'm totally fine with used tooling!I've got BS9 tooling if anyone needs some........
Daryl
MN
I make my own tools for my B&S 9 spindle. I turn the #9 taper on bar stock and then machine whatever I need on the other end. I make my own arbors for whatever I need.
Yep,
Making your own is a real option. Easy to do if you have a lathe. You can use the compound or a taper attachment.
Regardless, I'm pretty sure there is a BS9 boring head arbor with a 1 1/2-18 in the pile.
benzflieger, I'll check tomorrow and message you.
Daryl
MN
